Electric window not working drivers side 11 years 7 months ago #69216
I have a MG TF 2003, four years now. My drivers side window doesn;t work. HAve changed switches but they work on left fine. Tried to swap fuses and only one fuse works in left hand window. So I swap F4 and F5 and left and right windows don't work. Swap back and only the left hand side works. Does that mean it is the fuse as surely swapping fuses and the right window working would mean this? I have had the window regulator and motor replace brand new a few months ago. Any suggestions to what else it could be?
Welcome any suggestions.
Elaine
Re: Electric window not working drivers side 11 years 7 months ago #69221
:welcome: Elaine. Stand by for some answers and suggestions. Are you talking about a fuse or a relay? I'm off to check your manual. (it's free in our downloads section above).
Well, here's some of what's in the manual.
Anything new to you? Check the red boxes.
Re: Electric window not working drivers side 11 years 7 months ago #69223
  • bensewell's Avatar
I have a spare mech £25 and its yours :)
Re: Electric window not working drivers side 11 years 7 months ago #69227
hi what is a mech, sorry I am a woman and not sure of this technology?
Re: Electric window not working drivers side 11 years 7 months ago #69229
hi tried swapping the F4 and F5 fuses not relay? It that helps, wouldn't know where to look for relay.
Re: Electric window not working drivers side 11 years 7 months ago #69230
Its the electric window mechanism / or motor as other people know it :) No need to be sorry I'm didn't know anything about these cars before joining here.
Re: Electric window not working drivers side 11 years 7 months ago #69232
Is this different from the motor and mechanism inside the door, as I had a new motor and mechanism fitted this year couple of months ago as teeth had worn away
Re: Electric window not working drivers side 11 years 7 months ago #69233
i'm just on my way home, will log on when I get home in 30 minutes to look at this diagram. Leigh
Re: Electric window not working drivers side 11 years 7 months ago #69235
Click on them to zoom in for a better view. They're screenshots because you can't 'copy and paste' from the manual.
I'm not sure how to change the under bonnet fuses, as I've never had to do one. Anyone? They appeared to be screwed in.
Re: Electric window not working drivers side 11 years 7 months ago #69396
could it be the F18 fuse as it says this controls the lift on F4 and F5. How do I check. It is strange that I can swap fuses and both don't work, but when I put them back the left window works, which suggests something isn't getting through to that fuse socket.
Re: Electric window not working drivers side 11 years 7 months ago #69397
Invalid or non-existent item ID.it could be the window controller up th eduff like this one
Re: Electric window not working drivers side 11 years 7 months ago #69401
  • 's Avatar
  • Visitor
  • Visitor
Sounds like the motor to me :-?
Did you have any juddering problems before the window stopped working :-?
:welcome2:
Always lovely to have another female on board to keep the boys inline ;)
Time to create page: 0.964 seconds
