Reverse light switch 11 years 8 months ago #65137
A quick question I probably already know the answer to but.....
When I press the plunger on the reverse light switch, should I get continuity through the wires?
I know, its a switch, close the contacts and.....
The only reason I ask is that is brand new (well a year old but just taken out the wrapper and fitted today) surely I haven't been ripped off by flea bay :bang:
Re: Reverse light switch 11 years 8 months ago #65139
I would say yes, mate. Either way, continuity should alter with the plunger pressed.
Re: Reverse light switch 11 years 8 months ago #65149
Thanks David, I knew that was the case but with so much going wrong on this project I was hoping something as simple as fitting a new switch would be, well, simple.
Another new one ordered :rant:
Re: Reverse light switch 11 years 8 months ago #65167
When my reverse lights stopped working, I found that the end of the plunger had worn so that it wasn't depressed enough to complete the circuit. There was a thin washer on the switch that I removed and that extended the end of the plunger enough to work again.:shrug:
Re: Reverse light switch 11 years 8 months ago #65194
When mine failed even a new switch didn't fix the problem, so the part in the gearbox that depresses the switch must be worn.
I removed the washer and then used PTFE tape to ensure a good seal. That was over 12 months ago and it's still fine ;)
Re: Reverse light switch 11 years 8 months ago #65274
Thanks guys but I tested it out of the gear box and pushed the plunger manually. Definitely a dud.
I should have done that first, it being a new switch I assumed it was working and tried the usual problem areas of tracing a fault in the loom then adjusting the gear cables at the crank first. All in all a wasted couple of hours.
Reverse light switch 11 years 8 months ago #65404
Well if you need another switch, I have one you can have. I'll double check the continuity, but it was just fine when I tested it 2 months ago
The following user(s) said Thank You: davmor
Re: Reverse light switch 11 years 8 months ago #65460
Thanks Mal, saw this a bit late though and ordered one yesterday, it will be here tomorrow :(
Very kind though and I greatly appreciate the offer
Reverse light switch 11 years 8 months ago #65470
No problem :-) hope you get it sorted this time
Time to create page: 0.096 seconds
