Cleaning front arch...
Cleaning front arch... was created by a Guest
Posted 14 years 4 weeks ago #54414
If you have an hour or so spare it might be worth you cleaning the front arch where it collects dirt.
Just a couple of screws and pull the plastic inner arch away, water hose and jobs a good one....
Replied by Tourbillon on topic Re: Cleaning front arch...
Posted 14 years 4 weeks ago #54415
Gaz
Good call, my arches were really manky and i used the opportunity to clean and repair some surface rust on the inside of the arch. Bit fiddly to get the arch liners back though. :broon:
Just a point, I see you pics show the car on a the MGR jack. Not a good plan, always get the car on axle stands at the soonest opportunity if the wheels are being taken off. I had a car fall off a rover jack once and its not funny. :nonod:
T
Replied by a Guest on topic Re: Cleaning front arch...
Posted 14 years 4 weeks ago #54420
Very good point T about using MGR jack but there was an axle stand under the subframe just out of view..
This is how it is normally worked on:-
Replied by bensewell on topic Re: Cleaning front arch...
Posted 14 years 4 weeks ago #54428
Could you put something in the arch to stop or collecting again?
Posted 14 years 4 weeks ago #54430
The wheel arch and inner wheel arch could be sealed, but then it would make it difficult to keep checking this area.
Posted 14 years 4 weeks ago #54445
Gaz
Thanks for posting the pic of stand use. I didn't want to sound like a HSE inspector. We just don't want to loose MGer through dangerous DIY work.
On another point nice block paving, Mrs T would cut my **lls off if dropped a molecule of oil on that surface, you must be a clean worker :-)
T
Posted 14 years 4 weeks ago #54448
Gaz how do you keep the paving so grass free :-?
Mine has bits popping up everywhere :(
Nice cleaning work on the arch, I think I have half of a welsh field under mine :pinch:
Time to create page: 0.395 seconds
