first gear 11 years 11 months ago #52614
i have alittle problem getting first gear seems a little had to get sometimes.i find my self waiting at lights clutch down in first just in case when the lights change i cant find first .i rember seeing ajustment when i replaced gear gator has any fited this problem
Re: first gear 11 years 11 months ago #52618
you could try this first
http://www.the-t-bar.com/en/forum/54-how-tos/24204-curing-a-sloppy-gear-change--shorty-gear-lever
Re: first gear 11 years 11 months ago #52619
  • cjj's Avatar
Is it a loose gear change or just difficult to get into first.
If it is the latter it might be the clutch causing the problem.
Re: first gear 11 years 11 months ago #52620
no the gear stick is not sloppy feels nice and tight was thinking it my be the clutch as the pedal is feeling a little low but was hoping for a fix :(
Re: first gear 11 years 11 months ago #52621
Check the fluid level.
Re: first gear 11 years 11 months ago #52624
where will i find it :-?
Re: first gear 11 years 11 months ago #52629
  • PQD44's Avatar
Take a look at this handy How To by cjj Weekly Checks
You can see a photo of the clutch fluid reservoir, which you'll find under the bonnet, on the bulk head above and to the left of the windscreen washer reservoir.
Last edit: Post by PQD44.
Time to create page: 0.095 seconds
