LED 'how to' wire, resistors.
ok iv been swamped with question on what is the correct resistor for a led (on different forums so i thought is shair the info)
so today iv drawn up a few circuits to show how to measure the voltage drop across the led and the difference the power supply makes
a car supply can vairy from 11v to 13.5v so you have to work out the maths on the maximum values other wise things go pop
here is the first drawing
this is set up with a 13.5v supply 3v drop on each led and correct rsistor for 15ma supply
ok if the voltage drops to 11v then the values change as bellow note the current drop so the leds will dim if standard type
ok here is the same circuit with 1.6 volt drop accross the led and a correct reistor
so now if the voltage drops to 11v here are the new values
as you can see from the above circuit the current does not fall to much thus brightness is less effected
so by buying good quality leds ie mega bright the vf is lower than the standard type so produced a better light source and less vairiation in power
now if you say use 12v to set your led the 2 circuits bellow show at 13.5v (car alternator chaging ) you are above the max current of the led so its life is shortend and will eventualy fail
or if you dont know the volage forward drop then tha same applies
and for the peeps who want a dimmer here is a basic circuit
by MGF MARK
Last edit: 14 years 6 months ago by MGF MARK.
Replied by Red Devil on topic Re: led how to wire, resistors and I and do maths lol
Posted 14 years 6 months ago #36084
I have not got a clue what any of it means (I expect it is the Chav guide to hot wiring a car) but it looks very comprehensive Mark
by Red Devil
Replied by MGF MARK on topic Re: led how to wire, resistors and I and do maths lol
Posted 14 years 6 months ago #36086
well john next time your over this way ill show you how to do leds ect
by MGF MARK
Posted 14 years 6 months ago #36087
Thank you Mark that will be fab
by Red Devil
Replied by rog1963 on topic Re: led how to wire, resistors and I and do maths lol
Posted 14 years 6 months ago #36111
Nice job Mark.
Thanks
Thanks
by rog1963
- Leigh Ping
Replied by Leigh Ping on topic Re: LED 'how to' wire, resistors.
Posted 14 years 6 months ago #36140
Nice guide Mark.
Added to the 'how to' guides section.
Thanks for your efforts.
by Leigh Ping
Time to create page: 0.413 seconds
