Suplex Suspension - How to fit.(But Don't!)
- Rich in Vancouver
Replied by Rich in Vancouver on topic Re: Suplex Suspension - How to fit
Posted 12 years 2 months ago #46669Maybe we can make a deal to get those out of your shed, but I'm not sure if we should get Mark to put them in his luggage.
The X-Ray machine at the airport may get him into hot water!
I will PM you to talk about price.
I think the top stud of the shock is shaped that way because they have always been that way. :rant: I agree, a hex would be a very smart evolution.
I have a special wrench that works very well on the shock studs, (Much better than a standard 7mm wrench) although of course if someone has used mole grips on them previously you are in trouble. Unfortunately my daughter has my good camera at school today, and daughter #2 let the battery run out on the backup camera so it will be a couple of hours till I can get a pic of the wrench for this thread.
OK, camera chartged...Here's what I have found is the best wrench for the top of the shock. It is a Snap-On B1351A 3/16-1/4" brake wrench. The jaws are very thick and get a good grip on the shock stud. The wrench is also much longer than a standard 7mm, at over 20cm, giving very good leverage. Along with a ratcheting box end wrench it makes short work of removing the upper end of the shock.
Replied by David Aiketgate on topic Re: Suplex Suspension - How to fit
Posted 12 years 2 months ago #46670David
Posted 12 years 2 months ago #46987Apart from that the car has handled OK, but much softer, so better at handling speed humps and potholes. There is, however, an annoying clonk on speed humps and rough roads, which seems to be getting worse.
The overall ride is comparable with the hydragas but different...if that makes sense?
The best comparison I can come up with is that the ride is more like I'm running on 15" wheels with bigger sidewalls on the tyres, even though I'm actually on 16"s.
What does the team think on the subject of tyre pressures? I am tempted to nudge them up nearer TF levels; this may stiffen the ride a bit.:shrug:
Interestingly, the Suplex document makes no mention of altering tyre pressures.
- a Guest
- Visitor
- midlife martyr
Replied by midlife martyr on topic Re: Suplex Suspension - How to fit
Posted 12 years 1 month ago #47754Please Log in or Create an account to join the conversation.
Posted 12 years 1 month ago #48599David
Posted 12 years 1 month ago #486002 were full of liquid and one had just gone, judging by the small amount of fluid in it.:shrug:
- bryan young
Replied by bryan young on topic Re: Suplex Suspension - How to fit
Posted 12 years 1 month ago #48605David Aiketgate wrote: After a few hundred miles, the suspension has settled by 5mm all round , so is now 345mm front, 340 mm rear.
Apart from that the car has handled beautifully, as sporty as ever but much better at handling speed humps and potholes.
David, you could contact Suplex direct and ask what they think (they are running an F with their units on) or contact Roger Parker at MGOC he has got a set on his F and ask him too.
As the ride height affects the caster angle, i think it would be worth having the four wheel tracking checked after you are happy that the units have fully bedded in and adjusted to the correct dimensions.
It is good to hear about your results and that you are pleased with the system. :woohoo:
I have, therefore, added a link to my unhappy experiences, posted elsewhere on this forum.
- cjmillsnun
My advice, if you're going to fit the kit, think carefully about it, and DO NOT fit the dampers supplied. Add in the cost of GAZ adjustables and set 10 clicks rear and 7 clicks front as a baseline. Hopefully that will give you a good handling car without suffering the damage that David and I have.
And if you hear a ticking sound when you go over bumps, investigate immediately.
Replied by David Aiketgate on topic Suplex Suspension - How to fit
Posted 10 years 11 months ago #122074David
- cjmillsnun
