MGF broken front indicator clip
  • nellee
  • Apprentice MGer
  • Apprentice MGer
MGF broken front indicator clip was created by nellee
Posted 14 years 2 months ago #49935
Now this is a complete bodge, and im ashamed, and would never do this on my merc..... :whistle: :whistle:
so here goes, and sorry about the photos as the camera on my iphone is as crap as that stupid plastic clip..... :oops:
so the clip broke off yeah...? (see what i mean about the camera...!!!)
hands up if you thought of super glue, but knew anyway it wouldn't work....(that will be me then) so what else have we got lying around the garage that might do....?
Now with a self tapper ready, just chop the bottom of that little picture hook so you can get the screw through the hole already in it, and postition accordingly, I just started a small pilot hole in the indicator plastic with a drill first.
Bend to the appropriate position (now now boys) and TA DAH....!!!!! , mind i haven't tried to get it out yet...!!!! but it works a treat, good as new, and indicator happy as sand boy....... :woohoo: :woohoo:
is this what the rest of my life is going to be spent doing.......!!!!!!!!!!!!!!!!!! :omg:
Those Z3's look nice, and they are GERMAN....... :yesnod: :yesnod:
Last Edit:14 years 2 months ago by nellee
Last edit: 14 years 2 months ago by nellee.
The following user(s) said Thank You: Leigh Ping, Blow-in, TruckerClarky
Replied by David Aiketgate on topic Re: MGF broken front indicator clip
Posted 14 years 2 months ago #49936
Nice how to :broon:
Last Edit:14 years 2 months ago by David Aiketgate
Last edit: 14 years 2 months ago by Leigh Ping. Reason: fixed your thumb :)
The following user(s) said Thank You: nellee
Replied by Leigh Ping on topic Re: MGF broken front indicator clip
Posted 14 years 2 months ago #50133
Ingenious modding. :)
Replied by a Guest on topic Re: MGF broken front indicator clip
Posted 14 years 2 months ago #50140
Lol well done, another unique character to keep us entertained ;)
  • Humphrey
  • It's better to wear out than to rust out
Replied by Humphrey on topic Re: MGF broken front indicator clip
Posted 14 years 2 months ago #50141
;) I wonder if a picture hook is the answer to the great eternal question??
Maybe it could somehow prevent HGF?? :drive:
'I started off with nuthin and still got most of it left!'
You know, I spent a fortune on deodorant before I realised
that people didn't like me anyway!
Replied by TruckerClarky on topic Re: MGF broken front indicator clip
Posted 13 years 6 months ago #95819
;) ;) ;) :woohoo: :woohoo:
You sir are a saviour!!! Just had to carry out your "Mod" with top result, in fact indicators are more stable than before :broon:
Replied by DeanH on topic Re: MGF broken front indicator clip
Posted 13 years 6 months ago #95872
Done this Mod myself a couple of months ago, wouldn't have believed it would work if I hadn't done it.
Live Life to Laugh
by DeanH
Replied by Rich in Vancouver on topic MGF broken front indicator clip
Posted 13 years 6 months ago #95893
I'll have to give this a try. Only problem is my indicators are currently glued in place :(
Replied by Blow-in on topic MGF broken front indicator clip
Posted 13 years 6 months ago #95906
I'm removing my bumper soon to strip the lights and have the reflectors re-plated......this is therefore a very timely and helpful thread - thanks.
Richard
by Blow-in
Posted 13 years 6 months ago #97626
And yes, both the clips broke - I made something similar with a bit of springy metal and it is fine - I even managed to extract one of the lights with out breaking the new clip. The original clip has quite a complicated shape so that it locks in to a cut out but has a bit where you can compress it with a screw driver - with the 'new' clip you have to bend things a bit but is seemed fine again of refitting.
Richard
by Blow-in
Replied by davidgv1 on topic MGF broken front indicator clip
Posted 6 years 10 months ago #191313
I needed to get to the headlamp unit as the rubber surround had come adrift, so, removed the indicator, and, click, the stupid little clip broke off.
Superglue was useless, so I remembered seeing this “how to” and it worked, bloody brilliant. I just had to adjust the bend to clip into the bumper recess and Bingo, it worked.
A good saving on a new unit, and obviously it is tucked up and out of the way. And yes, I can insert a screwdriver at the side of the indicator and depress the clip and remove the indicator unit.
It took about 15 minutes to fix.
Replied by davidej on topic MGF broken front indicator clip
Posted 6 years 10 months ago #191333
I found that a piece of double sided foam tape does the trick
by davidej
Time to create page: 0.426 seconds
