  • 2
Tightening wishbone bolts. 9 years 6 months ago #152561
Hi, will be fitting new front wishbones soon.
At what wishbone position should the the inner bolts be nipped up as I believe they can't be finally tightened under compression as the rear bolt is not accessible with the frame fitted.
Tightening wishbone bolts. 9 years 6 months ago #152578
If I recall correctly, you've got enough access to get a socket on the bolt with the subframe in position. The reason for dropping the rear of the subframe is just that there's not enough room to extract the bolt.
The following user(s) said Thank You: john and Jake the dog
Tightening wishbone bolts. 9 years 6 months ago #152582
Hi David, I presume then that I can nip them up under compression. Thanks.
Tightening wishbone bolts. 9 years 6 months ago #152597
I'm sure CJJ did another excellent how to on this..
Tightening wishbone bolts. 9 years 6 months ago #152599
  • cjj's Avatar
Here you go. http://www.the-t-bar.com/forum/22-cjj-s-guides/90988-how-to-torque-the-lower-front-suspension-arms
You need a torque wrench and a crows foot socket to get the rear bolt.
Tightening wishbone bolts. 9 years 6 months ago #152653
Hi, good guide but a little beyond me with a car on the drive and a socket set.
I should get the same result by positioning the lower arm at a slight downward angle and then tightening.
Tightening wishbone bolts. 9 years 6 months ago #152658
  • cjj's Avatar
You really need to torque these bolts and I couldn't get a socket in there.
Tightening wishbone bolts. 9 years 6 months ago #152662
Hi, does anyone know how Rover did it on first assembly?
Last edit: Post by john and Jake the dog.
Re:Tightening wishbone bolts. 9 years 6 months ago #152663
Rover would have dropped the body onto pre assembled sub frame.
Sent from my iPad mini using Tapatalk
Re:Tightening wishbone bolts. 9 years 6 months ago #152664
Hi, yes, I thought they would with modern assembly.
Perhaps they assembled the subframe in a jig which allowed for compression of the spring with access to the rear bolt.
Re:Tightening wishbone bolts. 9 years 6 months ago #152666
Just had a thought. Assemble the spring ,shock,wishbones off the car and compress the spring either with a strap or spring compressors and then torque up.
If I can find the correct length of the spring when on the ground that should sort it.
Heath Robinson eat your heart out!
Re:Tightening wishbone bolts. 9 years 6 months ago #152667
:nonod: You'd have to remove the subframe from the car to do that.
  • 2
Time to create page: 0.123 seconds
