I was able to turn the screws with pliers then push the last bit through so they fell into the ducting.
Then it was easy to pop out the vent grille and fish the screws out with a magnet taped to a piece of wire.
I am getting a replacement dash ready to go into my VVC to replace the original sun-damaged dash.
Unfortunately the new dash arrived with all 3 tabs broken off it's binnacle (Just like the existing one
With the dash on the bench this time I tried drilling access holes in the back of the vent to get at the screws. This is easier said than done as it's hard to guess the angle right so I ended up with some extra holes. Not a big deal as they can be easily plugged.
I have repaired the bits broken off the binnacle with an epoxy filler and made up new tabs from aluminum strips which I riveted in place with flush aircraft rivets.
The last step will be to skin the binnacle in carbon fibre. That is real carbon fibre not a dip or vinyl.
Back view of the dash. The holes with tools in are the proper ones.
The binnacle with the alloy tabs bonded in place prior to riveting.
This vies shows the rivets in place. The repairs to the damaged edge are also visible.
Here is a link to the carbon fibre supplier.
Carbon Mods
I plan on using the Skinning Kit (3rd item down)
