I feel a lot more comfortable when I wear a belt in conjunction with my braces; specially if out on the town for a few pints or real ale.
On a more serious note torsional stiffness is quite difficult to achieve on a convertible as its only the floor pan/tunnel and sill structures that keep the car from folding in half when both doors are open.
Some torsional stress analysis has been done on the link below from ultimatemg.com. The TF does very well in this category as it is factory braced in some areas.
It shows the the ZT at the top of the table which is an unfair comparison as having a roof connected by pillars and bonded front and rear screen make a mono-flange passenger cell which is obviously not possible on a convertible.
The TF is a strong contender.
Brian.
http://mgf.ultimatemg.com/group2/body/
I did wonder if a monoflange was something I should have heard of!
Welcome to the Spelling Police to Constable Cobber.
Hi, I wanted more detailed information on the construction of the structure of stiffening of the body of mgf. for example, tubes of the structure are all of the same diameter?
Most of the tube work is 20mm.. 3.4mm wall thickness.. Usually CDS if I have it
As is often the metal that composes the tube?
What material are the tubes? Steel.. As its cheap and easy to work with
Of which are thick, where the plates are welded to tubes? Mounts are all 6mm plate or 6mm angle
thanks
I have many questions yet, but proceed a little at a time
We need a manufacturer to start making/ supplying bolt on braces for our cars
If I type c*o*c*k when I submit it you get flange?
