Re: Bonnet gas struts
- Diesel Destroyer
They open the bonnet to same height as the original bar..
The lower end of the strut mounts to the centre hole on the wing.. The kit comes with the fittings needed
The upper mount is a little more tricky... I opted for welding the supplied ball joint to the bonnet hinge.. The hole for the ball joint is already in the hinge.. But fixing it to the hinge is tricky.. So opted to weld it on (ball joint is stainless)
Only real issue is the lower ball joint mount fouls the bonnet when shut.. So had to dress the underside of the bonnet back a little with a ball pen hammer
- Diesel Destroyer
- Luckymarine
- Diesel Destroyer
Anyone with welding experince.. 45 min job
- a Guest
- User
Diesel Destroyer wrote: . Happy to help
Added to my list
- Diesel Destroyer
Or source spare hinges and post them to me?
Takes 2 mins to weld the bits on
It makes a real difference not having that bar in the way at the front
:lol:
Damn painful too!
Perhaps you need a hard hat too :lol:
Allan your offer to weld peoples bonnet hinges is a very generous, thank you
- a Guest
- User
PQD44 wrote: Would also stop the bonnet dropping on my head when I forget the MGF doesn't have gas struts like my other cars :pinch:
:lol:
My boot is by far the worse :pinch:
Since fitting my rear spoiler it has hit me on the head 7 times
- Diesel Destroyer
I want the gas struts to lift the boot lid on their own...
