Re: Seat belt nightmare, idiot shut it in the door 11 years 7 months ago #69409
You'll need to take the handle unit off the door, to refit it, or to glue it successfully.
As I say, if the clip is broken I am happy to send you the clip off this one.
edit -The problem with glueing is that the plastic clip needs to be able to rotate in the hole of the door lever in its operation.
Re: Seat belt nightmare, idiot shut it in the door 11 years 7 months ago #69412
do the clips just clip on then and pull off? Will that secure the cable in place?
Re: Seat belt nightmare, idiot shut it in the door 11 years 7 months ago #69415
The plastic clip is (should be) a tight fit into the lever hole. The plug needs to be pushed into the hole before the cable end is put into the clip.
Once you put the cable end in, you turn the clip around and the cable pushes into it.
I'll try and take a close up photo of this one to show you how it works, hang on.
Re: Seat belt nightmare, idiot shut it in the door 11 years 7 months ago #69419
OK this is with the clip removed looking from the back.
The clip ready to be pushed in.
Re: Seat belt nightmare, idiot shut it in the door 11 years 7 months ago #69420
The clip pushed into position in the lever.
Re: Seat belt nightmare, idiot shut it in the door 11 years 7 months ago #69421
The cable end going into the clip.
Re: Seat belt nightmare, idiot shut it in the door 11 years 7 months ago #69422
Cable in and clip being rotated.
Clip attached to cable end.
Re: Seat belt nightmare, idiot shut it in the door 11 years 7 months ago #69423
Everything in place.
The following user(s) said Thank You: p3charmed3
Re: Seat belt nightmare, idiot shut it in the door 11 years 7 months ago #69440
May I buy the clip off you?
Re: Seat belt nightmare, idiot shut it in the door 11 years 7 months ago #69442
David Aiketgate deserves the helpful person of the day award!
Richard
Last edit: Post by Blow-in. Reason: late onset dyslexia
Re: Seat belt nightmare, idiot shut it in the door 11 years 7 months ago #69443
pm me your address, I'll send it to you FOC.
The following user(s) said Thank You: Leigh Ping, p3charmed3
Re: Seat belt nightmare, idiot shut it in the door 11 years 7 months ago #69997
Hi David
I just wanted to let you know that I haven't received the lug yet? I didn't want you thinking I was being rude as not to say thank you on receipt. May be it will come today. I received motor from the guys you recommended, it arrived yesterday and garage are swapping them tomorrow. Have a good weekend!!
Time to create page: 0.113 seconds
