Windscreen washer return valve bypass.
Windscreen washer return valve bypass. was created by Leigh Ping
Posted 14 years 1 month ago #52647
Bypassing the windscreen washer return valve improves flow to the windscreen washer jets.
If you have a 'slow flow' to your screen then this is a 2 minute improvement that can be easily reversed if required.
Last Edit:14 years 1 month ago by Leigh Ping
Last edit: 14 years 1 month ago by Leigh Ping.
Replied by David Aiketgate on topic Re: Windscreen washer return valve bypass.
Posted 14 years 1 month ago #52659
Nice one Leigh.:broon:
I just cut the valve out off the piping and joined the two ends with a sleeve of slightly larger diameter piping.
Replied by Leigh Ping on topic Re: Windscreen washer return valve bypass.
Posted 14 years 1 month ago #52661
Thanks. 'Talking cars' (James) got me going on this mod when he mentioned how his flow improved dramatically. I ordered some xsara jets too. I'll post an additional 'how to' on those once they arrive. Being a non mechanical person, I like the 'easy mods' best. :broon:
Right now I still have the old movable, rotating nozzle jets fitted. They're hard to adjust with a pin, as we all know. I have the far left one pointing to the kerb area. That way I can squirt MX5 drivers whilst overtaking. :lol:
Posted 14 years 1 month ago #52664
Yeah, back when I was adding my heated washer mod I took the NR valve off. I tried blowing through it and nearly got a hernia.:rofl: Straight in the bin! :yesnod:
Posted 14 years 1 month ago #52665
David Aiketgate wrote: Yeah, back when I was adding my heated washer mod I took the NR valve off.
I plan to have a go at that mod come winter time. Although, I never really suffered with frozen water in the hoses. It can't hurt and will give me something to do. :)
Airscarf warm air mods & Clingfilm tip - Warm air mod uses & screen freeze prevention tips.
Heated Windscreen Washers - Warming the washer pipes to prevent ice build up.
Replied by MartinW on topic Re: Windscreen washer return valve bypass.
Posted 14 years 1 month ago #52669
With the non-return valve gone, does it take a while for the washer pipes to refill after a long period of not using them?
A tip I was given by an MOT inspector is to always use the same brand of windscreen washer fluid to prevent gunge in the pipes as the different brands have differing additives and these react to produce the gunge.
by MartinW
Posted 14 years 1 month ago #52671
MartinW wrote: With the non-return valve gone, does it take a while for the washer pipes to refill after a long period of not using them?
I'll report back on that one in time Martin. :broon:
As for gunge.. I once boiled a kettle, walked 15 seconds to the car, and put the very hot water into the washer bottle. Then I blasted it all out through the washers. The pipes / hoses were like jelly. But the slimey black gunge, that forms in the bottom of the washer bottle, came blasting out.
Posted 14 years 1 month ago #52711
Martin,
I ditched the NRV long ago. It takes at most 0.5 - 1 second longer for the fluid to hit the screen.
Replied by talkingcars on topic Re: Windscreen washer return valve bypass.
Posted 14 years 1 month ago #53357
Leigh Ping wrote: Thanks. 'Talking cars' (James) got me going on this mod when he mentioned how his flow improved dramatically.........................
Why, thank you. B)
Time to create page: 0.397 seconds
