Re: Uurgh! 12 years 4 months ago #35282
A familiar sight when our TF arrived. Since then I have adjusted the windows and sealed the heater inlet so the inside stays dry-ish. i also used some Autoglym kit to wash and seal the hood, now if it rains it beads and runs off. I think i just went over the inside of the hood with a faux chamois and it didnt come back . So it seems the mould needs water to flourish.
I wouldnt use trhe Autoglym again, our tame chemist at the Car Club uses tent sealer from Bkacks or Millets, same stuff but cheaper.
Re: Uurgh! 12 years 4 months ago #35286
Leigh,
I had some of the same mould in my car when I bought it. Diluted white vinegar did the trick for me.
Mark
95 MGF
Re: Uurgh! 12 years 4 months ago #35294
I have often considered one of those soft top liners but worry about not being able to see signs of mold.
Moisture absorbers, worth putting all the time or just over night, helps stop screen misting up too.
DRY AIR CAR/HOME DEHUMIDIFIER BAG MOISTURE ABSORBER
Completed
Set of 2 x Kontrol Streamline Moisture Absorbers Traps with Unscented Crystals
Completed
CAR CARAVAN DEHUMIDIFIER AIR MOISTURE ABSORBER DRYER
Completed
BRAND NEW 3 X SACHETS DEHUMIDIFIER BAGS STOP DAMP ABSORB MOISTURE
Completed
Last edit: Post by Red Devil.
Re: Uurgh! 12 years 4 months ago #35296
Sorry John I've messed your links up, can you redo them?
Re: Uurgh! 12 years 4 months ago #35298
No probs David, all done :)
Re: Uurgh! 12 years 4 months ago #35300
Completed
Re: Uurgh! 12 years 4 months ago #35301
I have something similar to the Kontrol Streamline. 2 can be trapped behind each seat. Only just started using them today so not really an expert on them just yet, however hopefully thy can soak up a bit of the moisture that's leaked in through the cracked rear screen over the past few months.
Re: Uurgh! 12 years 4 months ago #35310
They do work, my Daughter & Son-in-Law used them last winter in their house to collect the "puddles" on the window cills in the mornings. Double glazed windows in an aluminium frame, condensation on the ali. They do pick up a lot of moisture. :thumbsup:
Last edit: Post by PQD44. Reason: Unneeded quote removed
Re: Uurgh! 12 years 4 months ago #35312
leigh i used dettol spray and it worked hasnt come back on mine
The Dettol spray contains bleach which is known to kill mould, but it can bleach the colour out :rant: :broon:
Re: Uurgh! 12 years 4 months ago #35313
  • 's Avatar
  • Visitor
  • Visitor
Going by the amount of water collected in mine, I would stick with the ones that have the collectors underneath, I would be a tad worried that the pillow ones could drip or transfer moisture back onto the surface :-?
Re: Uurgh! 12 years 4 months ago #35314
I have an old 4 pint milk carton cut in half and half filled with rock salt, works a treat at capturing the mosture, when it is saturated I just bring it into the house for 24 hours. It will never collect so much mosture that it leaks water.
Re: Uurgh! 12 years 4 months ago #35316
  • 's Avatar
  • Visitor
  • Visitor
I meant the pillow version as opposed to a container :-?
Great idea re the rock salt though :thumbsup:
Last edit: Post by .
Time to create page: 3.760 seconds
Powered by Kunena Forum
