Passenger door lock jammed - Solved.
Replied by Tsleight on topic Re: Passenger lock jammed - yes you guessed it LOCKED!
Posted 14 years 3 months ago #44054
Another good luck!
Replied by adamelphick on topic Re: Passenger lock jammed - yes you guessed it LOCKED!
Posted 14 years 3 months ago #44068
OK, here's how the afternoon went:
Firstly I noticed that if i wanted to be able to lever the door panel off safely I'd have to somehow be able to get down behind it. So I levered the silver/rubber trim off the top of the card (pic is after the card came away but you have to EASE it out of the very small gap by the glass channel to start with!):
I took out the passenger seat and sat it outside the car (the seatbelt is long enough to stay connected!). Then I got inside the car and eased the door rubber seal away to give me some space:
Next I used a small toffee hammer to get the rear 'lugs' to pop. Put the rear part of the hammer against the screw and simply lever it!
You can then easily get the door panel to come away form the door at the rear (leave the front screw IN PLACE and DO NOT try to remove the panel yet!). Now you can begin to peel the door plastic liner back (annoyingly I had only just put it back and sealed it up!):
You can now get into the interior of the door:
Circled is the offending little sod!
You need to disconnect the power to the lock and you may just be lucky enough (I was after an hour of fiddling and tapping and squirting with WD40) that the bugger unlocks. Below is the connector you need to pull apart:
As I said above after fiddling for an hour this happened:
Once it had opened I immediately took off the lock, and also undid the front door panel screw and put the panel to one side. Its easy enough so I didn't take pics. But basically you undo the 3 star bolts on the door end, then unclip the outside handle rod, and then ease it out past the window channel (you MAY need to undo the TOP two window channel nuts and move it forwards slightly to get some space. Then you can get the interior door handle cable off the lock too.
As it happens Meg's orginal lock went faulty just after I refitted it (unbelievable I know!). So I then spent another hour making up a good lock from 3 I had in the shed! One had a grey set of stepper motors and another had a lovely smooth mechanism - so I combined the two and voila! I refitted as a reverse of the above. All was working well!
So I refitted the chrome/rubber top strip to the door card and then began to pop it all back together. I was so happy until I noticed this:
I managed to chip the door pocket that I had only just resprayed (after chipping it last year)...... GRRRRR. Anyway at least she now opens and closes properly!!!
Last Edit:6 years 2 months ago by adamelphick
Last edit: 6 years 2 months ago by adamelphick.
The following user(s) said Thank You: David Aiketgate, bryan young
Replied by David Aiketgate on topic Re: Passenger lock jammed - yes you guessed it LOCKED!
Posted 14 years 3 months ago #44073
That's a really useful how to Adam. :yesnod:
There are a number of people who have ended up in your position, but have destroyed the door card.
Was there much/any damage to the card/fittings using this method?
Posted 14 years 3 months ago #44075
Absolutely none to the card.. the two rear blue clip fittings lost a tag and so I popped some glue on them where they go into the holes in the door itself.. other than that it's a completely damage free method.
Posted 14 years 3 months ago #44080
You need to extract the How to out of this thread, Adam, and stick it in the How tos! :yesnod:
Posted 14 years 3 months ago #44143
Ooh so i do!
Replied by Rich in Vancouver on topic Re: Passenger lock jammed - yes you guessed it LOCKED!
Posted 14 years 3 months ago #44153
Well Done Adam!
Now you won't have to drive alone.
Nothing like a bit of thought and perseverence to solve a problem! :broon:
Replied by Laz1957 on topic Re: Passenger lock jammed - yes you guessed it LOCKED!
Posted 14 years 3 months ago #44155
Absolutely amazing job there :yesnod:
You must have the patience of a saint ;)
by Laz1957
Replied by MGF MARK on topic Re: Passenger lock jammed - yes you guessed it LOCKED!
Posted 14 years 3 months ago #44158
nice one :broon: ;)
where thers a will thers a way :broon:
dont forget to put it into the how to and what about doing the door lock repair how to :broon:
mad about cars and bikes :)
Replied by a Guest on topic Re: Passenger lock jammed - yes you guessed it LOCKED!
Posted 14 years 3 months ago #44172
Result, well done :broon:
Replied by Leigh Ping on topic Re: Passenger lock jammed - yes you guessed it LOCKED!
Posted 14 years 3 months ago #44174
Another great guide Adam. Nicely done. :broon:
Replied by Tourbillon on topic Re: Passenger lock jammed - yes you guessed it LOCKED!
Posted 14 years 3 months ago #44188
Well done Adam!!
Time to create page: 0.489 seconds
