Carpet troubles - How to fix
So I bought some of this from Halfords to stick the edge of the carpet down.
Extra strength hook and loop sticky backed Velcro.
I cut a length to cover the curve.
Placed it under the edge of the carpet and used a marker pen to mark the edge of the curve.
And trimmed it to suit
Cut a length of the opposite Velcro and stuck them together
And trimmed that to match
Next I pulled the edge of the carpet out and cleaned the metal with thinners to degrease it.
And did the same to the carpet
I then removed the backing from one side of the Velcro
and carefully stuck it to the metal so that it followed the curve.
Stick the opposite piece of the Velcro to the inside of the carpet.
And push the carpet back into place.
It should now stay where you put it.
Do the same to the passenger side and there should be no more swearing
Replied by David Aiketgate on topic Re: Carpet troubles - How to fix
Posted 14 years 11 months ago #27217I did try this a while ago, but it didn't last long. The velcro stuck to its opposite well but the adhesive came off the metal bodywork.
I forgot to clean the surfaces before applying the velcro, so it was probably my own fault.
- a Guest
- User
Posted 14 years 11 months ago #27222I do have another 'fix' under test at the moment.
- adamelphick
Replied by adamelphick on topic Re: Carpet troubles - How to fix
Posted 14 years 11 months ago #27264Tigger wrote: Mine's been a better fit since i replaced the under carpet felt with closed cell foam - i think it's thicker than the original so lifts the carpet up, closing the gaps.
I did a similar thing in Meg using the underlay from Fleur as I broke her up.. double thickness raised the carpets up enough to keep the carpets in place. The knock on was it also stopped some road noise!
Posted 14 years 9 months ago #29226Is it still working?
Replied by MGF MARK on topic how to repair your ripped carpet in your f / tf
Posted 14 years 4 months ago #40448Just thought id share this with you as to save money
My carpet was ripped at the foot well so I removed the carpet and sewed it back together
Making sure that the pile was covering the threads
Then I covered the back of the carpet with evostick and covered in duck tape and then added some more evostick, shaped the carpet to the correct shape during the glue going off,
Now I have a carpet with no rips and looks good as new
- a Guest
- User
choose colour and size (also hard top roof linning)
