Handbrake light flickering - How to cure it.
Handbrake light flickering - How to cure it. was created by David Aiketgate
Posted 16 years 9 months ago #204
OK you are finding that sometimes your handbrake warning light will flicker on and off as you drive along.
Firstly this light doubles as a low brake fluid warning - so check that.
Secondly, if your rear callipers are seized so they won't adjust or your handbrake cable has stretched then the actual handbrake lever will feel floppy and the light will flicker or come on all the time.
Do NOT continue to tighten the cable as this will cause the rear brakes to bind. The cable should be adjusted until the little levers on the rear callipers are just still resting on the stops(or no more than 1-2mm clear).
However, sometimes even if your rear callipers are correctly adjusted, the cable is also tightened properly and your fluid level is fine, the light still flickers on.
In that case it can be down to wear on the light switch
I removed the handbrake gaiter and had a look at the switch. Now, whether it's because the button has worn down through wear against the metal handbrake, or it's just a poor bit of design, I don't know but the problem is obvious.
The button only protrudes a few mm, meaning that the handbrake has to be almost fully depressed to get the light off.
The answer, to me, was to lengthen the button somehow.(notice how I avoided any reference to ****s there?)
So this is what I did. First chock the wheels, as you will be disabling the handbrake, and you don't want to end up in somebody's garden.
I pulled the gaiter off the handbrake, it just clips in, front and back.
Then I removed the cubby box to expose the cables, and I screwed out the adjuster until I could pull the handbrake up to vertical and out of the way.
Now you can see the switch, it is held in with two small screws.
If you remove the ashtray and surround ,you can get at the screw heads with a stubby screwdriver. Remove the topmost screw, and then loosen the bottom screw.
Now you can rotate the switch until it is horizontal, by pushing the top of the bracket down. With the switch now horizontal, and the handbrake out of the way, you can carefully drill a 2mm hole directly into the switch button. It only needs to be about 5mm deep.( you will see that the handbrake connects with the button on one side, so the hole needs to be over to that side)
What you do now is find yourself a nice 3mm fine-threaded screw about 10mm long. Fit the screw into the hole and screw it down leaving it sitting 5-6mm proud. Now you have a switch button that sits well up.
Pull the switch back into position and refit the bracket screw. Tighten both screws and refit ashtray.
Refit gaiter and tighten up your handbrake adjuster until you're happy with the pulled/on position.
Refit cubby box.
You will see that now you don't have to have the handbrake adjusted up so tightly, and you will also find that from the off position it needs a positive pull to get the light to come on. Result!
As a plus point, Sheila tells me it's a little easier to pull the handbrake on and off, so Brownie points for me there, then. LOL
Oh and DON'T forget to unchock your wheels before you try to move the car. Not that I did that; oh no not me, never. How could you think that? :outtahere:
Last Edit:15 years 8 months ago by David Aiketgate
Last edit: 15 years 8 months ago by David Aiketgate.
Replied by Blow-in on topic Handbrake light flickering - How to cure it.
Posted 9 years 10 months ago #171182
I have this problem too - handbrake light flickering on going over bumps despite the cable adjustment being OK.
Before I try this fix David - is it still OK after all these years? And am I right in my interpretation that the fix is to lengthen the button by putting a self tapper in the top of the plunger?
I'll try to take some pics when I get round to doing it.
Richard
by Blow-in
Replied by David Aiketgate on topic Handbrake light flickering - How to cure it.
Posted 9 years 10 months ago #171198
:yesnod: :broon:
I also found that another issue is the internal spring becoming weak/breaking inside the switch.
Posted 9 years 10 months ago #171203
David Aiketgate wrote: :yesnod: :broon:
Yes, I suspect that a worn/weak spring is the issue here, providing insufficient force to keep the plunger in contact with the handbrake lever. Rimmers list the switches as EEP191 at £19.49 inclusive VAT + delivery so a new switch in probably the better longer term answer.
Richard
Last Edit:9 years 10 months ago by Blow-in
Last edit: 9 years 10 months ago by Blow-in.
Posted 9 years 10 months ago #171206
So I took a look at my switch by loosening the handbrake gaiter which clips in fore & aft.
The above was taken from the left hand seat and the switch plunger was quite greasy and this was making it resist sliding in so that it was pushing up sufficiently on the handbrake lever that it wasn't staying in the completely down position. The plunger has to move about 3mm down before it extinguishes the handbrake warning light. With the lever released but not going completely down it only had to move a mm up for the light to come on. This indicated to me that there was plenty of life left in the spring.
Before trying David's trick which I could see would work, I cleaned the plunger with a blast of WD40 and some tissues then worked the mechanism for a few minutes. All of a sudden the handbrake lever was going completely down. While the light still comes on the moment you move the lever, the lever seemed more inclined to stay down and a road test over the same roads that gave me a problem earlier in the week didn't cause any unwanted lights so fingers crossed that it's sorted (and the WD won't dry sticky - I did remove most of it). Otherwise I'll use David's fix - I don't think now that a new switch would help.
Richard
by Blow-in
The following user(s) said Thank You: David Aiketgate, richardgr88, graham1, Skidpan
Replied by Fil6909 on topic Handbrake light flickering - How to cure it.
Posted 7 years 4 months ago #189677
Hi, I have this problem on my newly acquired '99 - mgf. not got my hands dirty yet , but I'm assuming this procedure essentially 'packs' the switch further forward, therefore the on /off button is effectively lengthened and comes into contact quicker , sounds easy enough👍. ... fingers xd thanks
by Fil6909
Replied by Skidpan on topic Handbrake light flickering - How to cure it.
Posted 7 years 2 months ago #190182
Richard, your procedure worked for me, so thank you, no more annoying flickering of the handbrake light while driving.
Last Edit:7 years 2 months ago by Skidpan
Last edit: 7 years 2 months ago by Skidpan.
Replied by Pharg55 on topic Handbrake light flickering - How to cure it.
Posted 6 years 2 months ago #192996
I had the same problem, turned out that the handbrake actuator was seized, wouldn't return to fully off position, the previous owner had over tightened the handbrake cable, to compensate for the lack of handbrake efficiency, which meant the handbrake wouldn't go fully down, which caused the problem.
I pulled the seal off the actuator mechanism, flushed it with WD40, repacked with grease and worked it several times, re-adjusted the cable, it's been fine since!
Now I've got to work out how to get the seal back inside the actuator!
by Pharg55
The following user(s) said Thank You: cairnsys, richardgr88
Replied by richardgr88 on topic Handbrake light flickering - How to cure it.
Posted 5 years 8 months ago #194435
Thanks all! Had this problem today - will have to have a look at the weekend :-)
Time to create page: 0.434 seconds
