Andy's Back-to-front Project 11 years 1 month ago #109243
:broon: :yesnod: :woo2:
Andy's Back-to-front Project 11 years 1 month ago #109396
Very good reading and like the wheels (thank you birks) I managed to get a new set of 11 spokes from magicwheels for £170 on ebay going to put Toyos on them and give back the borrowed ones.
Andy's Back-to-front Project 11 years 1 month ago #110044
Nice work Andy - I would love a set of those wheels as well :nv: bit outside my budget for now....... but you are scaring the life out of me .. I haven't jacked mine up yet and had a good look underneath ... got a few rust spots alreadyto sort ....so bracing myslef for the worst !
Great thread by the way - :broon:
The following user(s) said Thank You: benham
Andy's Back-to-front Project 11 years 1 month ago #113200
Coming soon....
Starter button v2.0
Regards,
Andy
Andy's Back-to-front Project 11 years 3 weeks ago #114861
It's been a while, I had a week off of work that I planned to solely spend on the car; alas like the best laid plans, that didn't happen....
However in the odd hour or two I've managed to snatch, firstly I removed the sump again, put another thick coat of white Hammerite on it, refitted, damn thing leaked like a sieve (not enough silicone) remove the sump again, another nice coat of Hammerite whilst it was off, refitted again, no leaks this time....
...realised I'd forgotten to put the sump baffles back in, removed the sump again, half way through putting silicone on to realise I'd run out of silicone, got annoyed and left the thing in bits for a day or two to sulk....
Swapped the alternator out for the exploded one... This is jammed solid and a post mortem revealed it was nothing but "cattle-trucked" inside....
Yeah, your guess is entirely as good as my one....
On went the new exhaust manifold (again) I need to slice off the mount for the OS heatshield (can be seen bent up in this picture) as the bolt was entirely round when I went to remove it... bugger!
And eventually the sump went on, as did the new mid-section.
Oh, white makes it dead easy to spot leaks, also a suspect "weep" can be identified by wiping the sump with a rag to clean it, then the leak is dead-easy to locate! A tip I learned from kit-car building.
Then I had a problem with the cat...
No, not Henry gaw'd-bless-im, but the catalytic converter, frankly this is only for the MOT, and I mashed the bolts up trying to split the catalyst from the downpipe and backbox long ago, I just sliced it all out with an angle grinder and threw it in a heap, now it was time to reclaim the catalyst.
"Serious" cordless angle-grinder, every home should have one! Nearly £380 one of these will set you back though! As an aside if you're in a trade I can't rate Metabo tools enough, I won't use anything else now!!
I cut the catalyst free, but the damn bolts would not budge out of either end of the catalyst, I tried all the usual methods including propane torch, freeze-spray and even my 16lb 'Percy', nothing would move them.... As the catalyst is for "MOT day only" I've found a method of removing the splined bolts, it's a bit destructive though:
I cut a slot though the mounting flange of the catalyst and in to the splined remainder of the bolt to release the compressing force on the bolt, then with a deft blow with a club hammer they all just popped out...
The culprits, these had nearly welded themselves in to the catalyst.
Some bolts I had kicking about just to fit the catalyst for now....
Ta-da!
Oh, and this to the naked eye looks like perfectly flat and smooth underseal (this is two coats worth) however the camera flash tells a rather different story....
That's it for now!
Regards,
Andy
Last edit: Post by benham.
Andy's Back-to-front Project 11 years 3 weeks ago #114867
  • John and Sue's Avatar
Your fortitude in the face of adversity is admirable, Andy. As is your approach to the various jobs tackled.
Keep up the entertaining posts! And the best of luck with the project as it unfolds.
Andy's Back-to-front Project 11 years 2 weeks ago #115304
Thanks very much!
Got bored yesterday, deemed it was time to get the exhaust on so I can at least run the engine up (not for any real reason, but it hasn't run since January.)
I got two new replacement rubber back-box mounts and the U shaped brackets that hold them up (mega bucks from B&G for a little piece of pressed steel) - and went to fit the back box, except the captive nuts in the rear chassis rail broke....
The welds on this plate seem to have a very deep penetration, coupled with crappy steel underneath I just drilled through through the welds, I'll plug-weld the plate back on then seem weld it tomorrow.
On goes the back box, much bending of hangers and fettling to get it to sit reasonably straight and in line with the bumper....
Started the engine, and pretty underwhelmed to be honest, not sure what I was expecting but doesn't sound that much different to the knackered OE system I removed, it could be because the engine is a horrible tappy mess with no induction system at the moment however.
Regards,
Andy
Time to create page: 0.099 seconds
