Hello, good morning! Well, there has been som progress since yesterday, but the main issue is still not solved... Yesterday night I connected the pscan to a 2004 MGTF, connection was ok and I could read his EPAS ECU, no faults. I checked my battery voltage, 12,7 volts, did alltohugh charge it over the night.Today, first, I got connection to the airbag ecu! Second: I got connection to the engine ecu when selecting MEMS 1.9 (is that right? (missing user manual....?)). Some error codes came up: 1,2, 27 and 28. But there is still no connection with the EPAS ECU. Do you still want med to connect an ammeter and short pin 7 as you suggest? My problem is to locate pin 7. I do have the electrical workshop book, but it does not number the diagnostic-connector pins. Thanks for your assistance.
