The cheaters don't leak but everywhere else does unless I juggle with the switches so I thought just adjust the windows. I'd heard the horror stories but how hard can it be, all you have to do is balance the adjusters A, B, C, D, E, F, G and H.
Monday will be day 4 by no means full days my patience just gives out and I go for a walk, on Fri the window stop jumped over and locked the window which has never happened before, so today I refashioned the upper adjuster to give more than the 2/3mm overlap that it had previously. But I failed again to undo the crosshead screw in the window stop so I can rotate it, my brain just doesn't work when I can't see what I'm doing.
I've looked at the cheater mountings and there is quite a bit of adjustment front to back but very very little in or out. So far I have cramped them in as far as I can by releasing the bottom mount then tightening the bolts but twice so far they have crept back out again when the bottom mount is reattached and the door is open/closed a few times. To me it seems that the angle between the lower metal window channel and the cheater needs to be more acute but hopefully this will resolve itself when all the other adjustments are done.
