Hi Mark
Yes when you start i will be clear. To get to the front suspension arms you have to remove the front bumper and crash can. It is not difficult but it all takes time.
Also removing the hydragas spheres is straight forward, but again the space is limited and therefore you have to puzzle a bit.
I did my conversion on 2 x 6 hours and had no issues as snappes bolts or so.
I have set the car at the lover limit in the standard ride height range and the suspension adjusted as mentioned in the instruktions from Mike Satur.
At the first drive i at once noticed, that the suspension was firm but comfy. The handling was a little “stiff” and the directionally stability was not good. I could see, that there was a toe out on the front wheels. After a wheel alignment the car is driving absolutely perfect. (Only the front wheels was adjusted)
I had to correct the ride height a little after some driving.
I am sure you will be pleased whit the conversion..
My only concern is how it will go when MOT time comes next autum, but then again in Denmark the MOT men dont know how a MGF is built as it here in Denmark is a very rare car.
