Stainless coolant pipes 5 years 11 months ago #185166
https://www.arnoldclarkcustomerservices.com/Evhc/ViewCheckList.aspx?uid=8bc92474-5cf9-4337-b2e0-5ae93cea1ecf&rnd=1246
Do you reckon my pipes are the standard ones or stainless?
Also, whilst you are looking at the car, how bad is the subframe? What would I paint or treat it with?
Ignore the "oil leak" at 2 mins in. The drain plug is out, the inspection is referring to a previous leak when I had a camshat seal failure (I think)
thanks!! :)
Nick
Stainless coolant pipes 5 years 11 months ago #185167
Hi Nick.A bit hard to tell but I would say by the looks of them that they are standard ones ( not stainless ) . When I bought my TF 4 years ago the pipes looked like that and as I was wanting to uprate the H/G I changed to stainless . As for the rust on the subframe , I think you could do with a good wire brushing and a coat of rust converter of which there are many on the market. Then it's a case of painting with smooth Hammerite . The lower wish bones might be as bad on the inside where you can't easily get to so just do your best with them . My TF looked just as dry and unprotected as yours and was a bit of a pain in the arse to sort out . There are some who would say that taking the subframes out is easier than doing it in situ but that's not a job that many people can do ( Talkingcars, James is in the process of putting his back in I believe ) . I am sure there are folks on here who will suggest something better , just do your best .
John
Stainless coolant pipes 5 years 11 months ago #185168
your floor pipes are steel, the stainless doesn't really lose their color, the subframes will be ok if you get a good drill with a wire brush on them, but for safety reasons, I would change the wishbones as some are known to have a fault that weakens them, use red lead and under seal on the subframes and they should come up like new, not an easy job but well worth the effort, I have seen them a lot worse than your's, has the engine cooling pipe been changed to stainless ? as these seem to go, I mean the pipe with the water bleeder on it? good luck, :broon: :broon:
Stainless coolant pipes 5 years 11 months ago #185169
you can normally tell if a pipe is stainless or mild steel with a magnet......a magnet is very atracted to mild steel....stainless is normally none magnetic....but even some stainless will be atracted to a magnet normally where a bend is formed in a pipe....has the molecular structure can change has its bent.......i bought some a2 grade stainless bolts......you can slightly atract them with a magnet....mild steel will jump at it like a red rag to a bull.....stailess steel varies alot depending on the aplication ....stainless pipes for the mgtf are normally advertised as a2 grade stainless steel
Last edit: Post by mgtfbluestreak.
Stainless coolant pipes 5 years 11 months ago #185172
Neat way to get an inspection.
They aren't stainless pipes.
I would look at the less visible parts of the subframes and consider dropping them to get them cleaned up, they have less paint than the ones I took out.
Stainless coolant pipes 5 years 11 months ago #185427
If I start cleaning the subframes and whishbones and other bits, do I paint with black hammerite or one of the underseal waxes? Or just a rust eater? I'll go for hammerite unless anyone advises against it - just simply because it's easy...
thanks!
Nick
Stainless coolant pipes 5 years 11 months ago #185433
I'm just doing my subframes and I have gone with wire brush, then rust treatment then spray on underseal. I think hammerite would tend to chip off more easily than a semi solid underseal. Personal opinion.
Stainless coolant pipes 5 years 11 months ago #185434
I invested in a Schutz gun system through E-Bay, it's impressive & everything has had a do, even next doors cat. The standard Schutz cartridge under seal is a bit thick to apply via the tube extension so I warmed some Waxoil until it became fluid & sprayed right down the sill by removing the side vents. Plain surfaces just get blatted.
I was trying to put a link in, but due to my ineptitude I failed, sorry.
Stainless coolant pipes 5 years 11 months ago #185435
Powder coat!
You'll be surprised how cheaply you can get this done, especially if you know someone who works somewhere that does it. A friend of a friend works in a spray shop for a factory that makes tube steel fabrications and a bottle of cheap scotch seems to be the going rate for some extra-curricular spraying ;)
It's one of my jobs for over winter if I can organise some workshop space.
Stainless coolant pipes 5 years 11 months ago #185436
so I warmed some Waxoil until it became fluid & sprayed right down the sill by removing the side vents..
I was an even bigger cheapskate a few years back when I did the 4x4... I bought a cheap pump type garden sprayer, pot waxoil in that and stood it in a drum if hot water until it was thin enough to spray. Worked treat !
Stainless coolant pipes 5 years 11 months ago #185535
I am heading into the last quater of my F to TF subframe swap.
I have cleaned up and hammerited the subframes in forrest green (the car is BRG) and all the attached bits in smooth black.
I have a large tin of waxoil in the shed ready to spray everything when I am done.
It looks like the car was professionally undersealed early in her life.
Time to create page: 0.123 seconds
