Wocha bin doin on your MG this week then? 3 years 6 months ago #194205
After many Years, it was about time to enhance our F with a new salon. Fully replaced with new leathers for Seats, sides and gear/handbrake gators.
Goodbye to old orange and welcome Black/Sun combination.
(Really happy with the outcome and with the competency of the repairer!!!!!)
Your new seats look amazing! I'd love some of this sorcery; probably a long shot, because it looks like you're on the continent, and I'm in the UK – who is the repairer?
Wocha bin doin on your MG this week then? 3 years 6 months ago #194207
Actually I am based in Greece so I believe it is a little bit far for you!!!!!!! ;)
Wocha bin doin on your MG this week then? 3 years 6 months ago #194210
Just a little :lol: Unless you are based on Crete, where I go at least once a year...
Wocha bin doin on your MG this week then? 3 years 6 months ago #194212
  • Bertl's Avatar
  • Bertl
  • in the middle of the midlife crisis
Just one day before Greece was put on Ireland's red list I checked for a trip to Crete... :bang:
as ever,
Rob
Wocha bin doin on your MG this week then? 3 years 6 months ago #194213
Bad luck Berti, though when things do not happen sometimes are for a good reason. It is better to visit Crete when all this mess will end as you will be able see too many things, experience, taste......!!!!
So do not give up and wait to re schedule it!!!!!!
Wocha bin doin on your MG this week then? 3 years 6 months ago #194228
Fitted front ball joints. Easy job.
Just ensure that the socket you use has been ground/turned to the socket faces. Many socket have a radius before the socket faces, and as the MG Ball joints have quite a thin hex on the joint, damage to the joints hex before it is removed may give you a problem.
Wocha bin doin on your MG this week then? 3 years 3 months ago #194849
Started changing my wheel bearings, started with the offside rear which I had an advisory on at the MOT. Surprised at how much play there was as it was only an advisory. Not helped by the fact that the hub nut wasn't much more than hand tight.
I'm also fitting the uprated shock absorber bolts as the MOT tester commented on the slight play in them. The uprated bolts are 1.35mm larger in diameter and are a snug fit I the bush.
Wocha bin doin on your MG this week then? 3 years 2 months ago #194911
The catalytic convertor needed changing. when i took the old one off i could see right through. no wonder it failed the emissions :uwp:
Last edit: Post by Postman87.
Wocha bin doin on your MG this week then? 3 years 2 months ago #194924
:clap: :clap: :clap: :clap:
Re:Wocha bin doin on your MG this week then? 3 years 1 month ago #195108
Stripped the interior due to numerous leaks. Rubbed then primed the metal panel behind seats and generally treated rust. Changed the passenger side mirror and cheater. Lots to do.
Sent from my Pixel 2 XL using Tapatalk
Last edit: Post by mrtsbrother.
Wocha bin doin on your MG this week then? 3 years 2 weeks ago #195306
Replaced all engine coolant and radiator pipes (rubber/PRT/metal). Now ready for summer!
Wocha bin doin on your MG this week then? 2 years 10 months ago #195824
Refurbing the front brakes.  Had a helluva job getting the pins out! I don't want to go through that again! Replaced the originals with Mike Satur uprated pins.
Time to create page: 0.313 seconds
