Got round to fitting my new slave cylinder, fiddlesome job but it went in ok. The top bracket was also replaced that the cylinder is bolted to, but the lower bracket was left, as it is quite a big job to remove due to one of the pins being obstructed by the gearbox supporting arm! This is probably best done with the subframe out!
I ended up having to replace the pipe under the car that leads from the master cylinder to the flexi hose too, as I found that this was too far gone when removing the old flexi. So a brand new kunifer one was bent and fitted.
I hear lots of people complaining about bleeding the clutch and what a pain in the bum it can be, but my mates easibleed got the air out in a matter of seconds!. Also managed to replace the damaged plastic clips under the car that hold the brake and clutch pipes in place and also a couple on the other side that fix the vacuum pipe and air con pipe. A good job to do and hopefully a trouble free clutch for years to come!
Sundance
New pipe....
New slave cylinder in place.
