Some advice please …
Took my treasure out for a spin today: top down, blue skies around 9 degrees C.
When I returned I drove the car over the garage door threshold and stalled with a bit of a jolt.
Upon re-starting, the engine indicator warning light stayed on! So I took it out again for a short test drive. The car drove normally. No obvious problems but the warning light remained on!!
I understand this light and the Malfunction Indicator Lamp are one and the same: am I correct?
I have looked at cjj's article on fitting a mil eliminator post cat and have checked to see if the sensor is connected at both ends. Everything appears ok.
The car has a standard cat and done around 61.5k miles.
I further understand there is another O2 sensor before the cat. Can someone tell me whereabouts so I can check if any connections are loose?
XO
