Yesterday my X reg 1.8i F would not start. Key in ignition and turned on, all dash warning came on and then went out, except the ones that stay on until engine startes (i.e. oil, engine, EPAS). Turned key to position 3 and nothing, not even a click or whirr from starter motor. In a hurry so took wife's car.
Today went to check everything out, suspecting bad/dirty connection for starter or something.
All fuses OK.
All terminals OK, starter, earth lead etc.
Still nothing.
Switched lights on to see if alternator/battery working OK, no prolems, no fade of lights or anything.
Switched lights of and turned key again and the car started!!!!!!!!!!!!
First time I have experienced this problem and have eliminated all the obvious ones I can think of.
My question is could this be the imobiliser?
If it is the imobiliser, how can it be resolved?
If not any other suggestions would be welcome.
Many thanks
Pete
Re all the above, this has happened twice more now, each time same symptoms. BUT have been able to bump start the car.
So presume not the imobiliser or alarm system.
Getting fed up now, as the wife doesn't know how to bump start and cannot push car by herself so ideas really needed now.
Thanks
Pete
