If you look along the bottom seam you should be able to see three 1/2 slots. Front middle and rear - you should be able to get a lolly stick or similar into them.
I remember ours were clogged and you could hear rushing water every time you braked.
Well I can confirm this area is DEFINITELY and MOT failure! Meg failed her last MOT on the same thing both sides so I cut it all out and made a new patch up and welded it all in:
Rust cut out completely and inside rust proofed:
Patch made up and ready for spot welds:
Spot and seam welded in:
Covered in Shutz:
So far no rust showing back! I have to waxoil inside still and want to find some of the rubbery bubble style shutz somewhere!
You need some Stone Chip coating which is sprayed on with a SHUTZ gun, it is what they used in the factory. You can buy it in aerosol cans from places like Halfrauds. BTW nice tidy repair
seen the pictures.the rear wing and sill are one panel ana this panel spreads the stress of the rear of the car,to do the job properly you need to cut of the rear wing off there will be corrosion on the inner wing and inner sill.these where never rust proofed at the factory.some garages will simply cut out the bad and weld in new.this is a bodge rear and can make the car weaker.I will send you some photos of a car that we removed the rear wing from.rust is cancer of the metal,it needs to be removed or it comes back more aggressive
