  • 2
How to Take a Door Off 11 years 9 months ago #57024
  • bensewell's Avatar Topic Author
So I took a door off while I've been tinkering. Here's how i did it...
WARNING Very Pic Heavy.
Step 1; remove the door trim using this guide by CCJ:
Door card. - How to remove.
Then take the internal hinge off by hitting it with a punch or waggling some pliers on it. You're aiming to pull it up and out.
Next time to take the speaker out. There's three cross head screws.
Then unclip the wire holder from its holder with a screw driver or pliers.. WARNING don't get giddy or you could break something.
Next theres a lot of wires in the bottom of the doors for the window mech. Be careful and unclip them.
The following user(s) said Thank You: philljoynes, Jimuth
Last edit: Post by Leigh Ping. Reason: Tidied up. Great guide. Thanks Ben :)
Re: How to Take a Door Off 11 years 9 months ago #57026
Next unclip the "Door Snake" that holds your wires in with a screwdriver.
And pull the wires from your door card up and out of the hole where the door snake lives.
So now the wires are out shut the door slightly and start taking the nuts off. You'll need a ratchet spanner or ratchet handle and socket like what I used.
But some of the bolts / nuts whatever you want to call em are a bit tight for the standard ratchet so I had to get the "mini me" 1/4" ratchet out to take the ones you can't reach.
Here he is bless him :broon:
The following user(s) said Thank You: tui
Re: How to Take a Door Off 11 years 9 months ago #57027
Now its magic time. You need to hold the door with your leg as the hinges are off or it will fall off and hurt you and your pride.
So press on the door with your knee then pick the door up from the other side. Theres loads of gaps in the metal to choose from.
So its off but it somewhere safe and scratchfree.
The following user(s) said Thank You: tui, Yellow Peril
Re: How to Take a Door Off 11 years 9 months ago #57029
Very well done Ben! :broon:
I particulary liked the clever graphics.
One question.....Why did you take your door off? :dry:
Re: How to Take a Door Off 11 years 9 months ago #57031
I'm stripping the mk2 F i have in my garage. Bought it for £300 had about £600 worth of parts and counting off it :)
Re: How to Take a Door Off 11 years 9 months ago #57038
Another great guide Ben. Cheers. :broon:
Re: How to Take a Door Off 11 years 9 months ago #57043
  • 's Avatar
  • Visitor
  • Visitor
another very quick way is to open your door just as a van is passing as one of my customers did,very fast and a very clean way of door removal.and you dont have the hassle of storage and lifting the dam thing.
Re: How to Take a Door Off 11 years 9 months ago #57046
  • 's Avatar
  • Visitor
  • Visitor
lol Daryl ...
Ben seriously well done babe, that is a great how too :broon:
Re: How to Take a Door Off 11 years 9 months ago #57455
  • tui's Avatar
  • tui
  • Penelope Pitstop
Great How To Ben! :broon: Amusing read too!
-=Visit my Website!=-
Re: How to Take a Door Off 11 years 5 months ago #85888
Is it possible to remove a door without removing the wing as well ?
Re: How to Take a Door Off 11 years 5 months ago #85890
  • cjj's Avatar
I'll tell you tomorrow. ;)
I am trying to take the hinges off (bottom one) and the only way I can see is to go in through the wheel arch, so tomorrow the wheel comes off and the wheel liner comes out.
Re: How to Take a Door Off 11 years 5 months ago #85892
I'll look forward to it .
Looking at it today I wondered if the door would go back far enough with the "stop strap" removed to allow access to the bolts on the door side of the hinges rather than the A pillar ones ?
  • 2
Time to create page: 0.148 seconds
