A cause of overheating in traffic is the radiator fuse fan blowing when the fan is triggered.
The first thing you can do is replace the 15amp fuse with a 20 amp. This usually overcomes the problem of the initial switch on of a sticky fan blowing the 15 amp fuse. MGR modified the fuse in this way in later models.
How can you know that the fuse hasn't blown leaving you open to engine overheats?
Dieter has fitted a small 12v buzzer to the circuit that sounds if the fuse blows.
This is his HOW TO.
You will need:-
- 12V buzzer with black and red wires
- crimp sleeve M4? (check bolt size be4 you buy, could be M5
- Y- connector
Disconnect the Battery to make safe.
Unclip the upper cover of the front(underbonnet) fuse panel
Remove the inner cover
to reveal the securing screws
Unbolt the fuse box.(2x 8mm or 10mm bolts)
Unclip the lower cover to reveal the wiring harness.
Locate the hole in fuse panel (see red arrrow) and lead the black (-) buzzer wire through the hole (from top to bottom.)
Locate brown wire at Fuse # F2 from below (blue arrow) and connect the black buzzer wire to it with a Y-Connector. OR Strip back some insulation and solder the black wire to the brown fuse wire. Use shrink insulation to tidy it up.
Lengthen the black wire if it's too short.
Close lower cover. Take care not to trap the black wire.
Place buzzer into fuse panel
Bolt panel back in place
Remove the hex-screw at the fusebox positive connection.
Crimp sleeve connector to red wire and bolt red wire with sleeve to the positive connection.
Reconnect battery, synchronize alarm blipper by pressing one button 3-4 times.
To Test the alarm:
Switch the ignition on and run engine
until the front fan activates.
The buzzer should not sound. If the Buzzer sounds or the fan doesn't operate as expected ... check your wiring and whether F2 fuse is blown
Now pull fuse F2.
---->Buzzer should sound
Replace Fuse F2
<---Buzzer should be silent.
If the Buzzer continues to sound ... check whether F2 fuse is blown
While we're talking about fan operation:-
The engine bay fan may not operating. To test it, disconnect the plug from the Ambient Air Temperature sensor here, with the engine running. The fan should operate. If not check the fuse.
