Hello, I am a male of the species and 63, took early retirement from my job as Engineering Manager at Colgate Palmolive in Trafford Park as the powers that be decided to build a new plant in Poland and close Salford, since I had been there for 30 years it was a good move so in 2008 I retired.
What should I do now, so I decided last month to get a little run about and looked at the MX5 but I couldn't safely drive it being 6ft 3inches, I then came across an MG TF hoard at a garage in Mossley called FatPhil's, he must have 12 F's & TF's, superb chap to deal with and good stock as well, I drove one of his and was hooked, so hey presto bought one, as below.
I have recently purchased a 2003 MG TF 1.8, 57K on the clock pretty much FSH and lots of bills. So being the cautious type and following the mantra, "prevention is better than cure", I have had a full service including oil, coolant and brake fluid change, filters and belts changed and st steel pipes underneath, then a check on suspension brakes and generally check the car out, all was well.
So far so good, then when it was ready I left the garage and drove away, 2 miles down the road run out of petrol, added 5 liters and tried to start it, it started at first but when I tried to rev it died and continued doing this until it wouldn't start at all, nothing dead, so it got towed back to the garage and am now awaiting results.
I generally think that it is the fuel filter because of the dirt it probably brought up from an empty tank, but lets see.
Any further ideas would be welcome.
I also run a BMW 520d SE auto, just because I am fanatical about reliability and this ticks the boxes.
BigPhil.
