Index
Alternator:
How to change the Alternator
Brakes:
Handbrake Light Flickering?
Handbrake - why is it so poor?
How to fit stainless steel braided brake hoses
How to replace rear calipers
Bumpers:
How to remove the Front Bumper
How to remove the Rear Bumper
Clutch:
How to change the Clutch
Coolant:
How to fill and bleed the coolant system
Low Coolant Alarm - How to fit one on the cheap
Engine:
How to remove the engine/rear subframe
Exhaust:
How to change the Exhaust backbox
The sweet sound of the Daytona
Gearbox:
How to top up/refill the gearbox oil
Head Gasket:
Head Gasket - Has it gone?
Radiator:
Radiator Change - How to
Tyres:
Tyre Size - Speedo reading
MGF/TF Recommended Tyres & Pressures
Locking Wheel Nuts
Interior Mods:
Fitting LED lights to your interior
Fitting Alloy Door Pins
Door Card Removal Guide
Carpets - Why don't they fit properly?
Exterior Mods:
Fitting K+H Splitter
DIY Trophy Headlights
Door Handle Removal guide
Polishing Petrol Cap Ring
Free Heated Windscreen Washers
Grilles on your MGF looking a bit shabby?
How to fit stainless steel underfloor pipes
Door Mirror Removal Guide
Glass rear screen in an F
Miscellaneous:
Sensors - outputs, readings, etc.
Misfire/hesitation under load
