Steering/Suspension issues 9 years 3 months ago #154055
I have recently had the work completed shown below, however I am suffering a scary steering issue when turning right. more or less around 1 or 2 oclock position.
- wishbones obviously with new bottom ball joints
- NSF top ball joint
- OSF shock absorber (used but approved)
- Front TRE's
- poly bush kit front & rear
- 4 point wheel allignment
TOYO's front & rear with 26psi F and 36psi R
When turning right at the position mentioned above I have the car, what would be described as wobbling left to right. Car is solid going to the left, turning further right than the 1 or 2 oclock position seems to be ok.
Bearings?
Suggestions?
Steering/Suspension issues 9 years 3 months ago #154057
I do have a bit of a clunk/creak from the OSF area when going sleeping policeman etc...
Steering/Suspension issues 9 years 3 months ago #154073
I would guess that something is loose. I would take it back to who did the work. :yesnod:
Steering/Suspension issues 9 years 3 months ago #154084
  • cjj's Avatar
Could it be some slack in the steering rack or maybe a faulty steering column?
Assuming the Steering rack is rack and pinion, there could even be a tooth missing or damaged on the rack, leading to a bit of play at that particular point.
Steering/Suspension issues 9 years 3 months ago #154224
jacked the car up quickly today before heading to work, OSF tyre has some play and on further investigation the top ball joint does have a small split in the gaiter.
Steering/Suspension issues 9 years 3 months ago #154375
Ok, garage has said that OSF top ball joint and NSF inner tie rod need replaced.
Garage is struggling to obtain a new NSF inner tie rod. Can we still get these from new? Had a quick look via Google and eBay but only had joy with used parts on eBay.
Steering/Suspension issues 9 years 3 months ago #154378
What's the inner tie rod? Do they mean the Anti roll bar link arm by any chance?
Steering/Suspension issues 9 years 3 months ago #154379
Track control arm? If so, they only sell the rack complete. If you do replace the rack get the TF rack as it is 'quicker'. It's a straight fit.
Time to create page: 0.128 seconds
