Hi all,
After a summer that started so well with the joy of my MG and trips planned including to the Scottish Highlands, things went a bit astray when I had an accident (NOT in the MG!!) where I tripped over a kerb and fell wrong breaking my shoulder joint .... so not such a good summer was had after all
Anyway, the upshot of this is that the MG has been sulking ever since I managed to get back on the road about a month ago. The latest incarnation of this was when the radiator sprang a leak (some body had previously used some form of rad weld and it appears that gave way). I stopped pretty sharpish and got relayed back home. The rad was replaced pretty easily (an easy job on an MG?? I didn't think it was possible!!), and I'm certain no damage was done to the engine or HG.
However ... since getting back on the road (again) the water temperature gauge seems to have stopped working properly (it never gets above the bottom two marks now, it did before) and the rad fan doesn't appear to be working (I'm not too sure this ever has worked looking back now). All the fuses are intact for the fan, so I'm thinking the relay has gone. I know you can take the relay out and put a wire across the contacts to check that everything else is working, but I'm not sure which pins / slots to wire across, can anyone point me in the right direction please?
Also, with the water temp gauge, could the sensor have got damaged when the MG had her sulk and got all thirsty? Is there an easy(ish) way of testing this? or is there a more likely reason for the sudden lowering of the temperature?
