What's your front subframe rust proofed with? 9 years 5 months ago #152348
Hi, had my 2003 tf a few weeks now and after some reading I thought it was time to drop the front subframe, strip it and rustproof all the bits.
Using a wire brush and Kurust but what should I paint the frame and hubs etc with.
What's your front subframe rust proofed with? 9 years 5 months ago #152351
Hiya John, most people use hammerite for the subframes, other alternatives include powder coating or even galvanising
The following user(s) said Thank You: john and Jake the dog
What's your front subframe rust proofed with? 9 years 5 months ago #152355
I did mine on my F with POR15 from Frosts, its a one pack polyurethane paint that is many times better than Hammerite, nothing will touch it after it has cured. it is a thick coating paint and two coats make a wonderful job - coat the insides with wax oil.
I also used the POR15 derusting treatment first. I also coated the new lower arms with POR15 before fitting. not cheap but very good, can be bought in small tins to avoid any waste.
Despite the comments it is not advisable to Hot dip galvanise a sub frame, the heat generated by immersing into molten zinc will distort the frame.
What's your front subframe rust proofed with? 9 years 5 months ago #152358
+1 on POR15... Did the very same....here's the link..
http://www.frost.co.uk/brands/por15.html?gclid=CJjs1JDVycECFYzHtAodnl0A2A
- Frank Zappa
The following user(s) said Thank You: c.steffan, john and Jake the dog
What's your front subframe rust proofed with? 9 years 5 months ago #152361
The cheap solution is kurust, hammerite then black waxoyl. You need 2 coats of everything and the kurust needs time to cure first. As it's hard to go black on black, you could do one coat of hammerite in a different colour. I'm sure there are more modern products out there and the MGOC supplies some hi tech German stuff - but it's expensive.
Richard
What's your front subframe rust proofed with? 9 years 5 months ago #152369
Ive got to get round to doing mine . They are starting to show alot of surface rust. But ill be goin down the krust black hammerite and wax oil route when i get round to it
What's your front subframe rust proofed with? 9 years 5 months ago #152586
Shotblasted and powder coated both mine, could have got it galvanized but was scared of it going missing when it was sent.
What's your front subframe rust proofed with? 9 years 5 months ago #152596
Hoping to get mine back in soon.....I wore out a wire wheel in the angle grinder, course wire wool vinegar water followed by kure rust, painted with rustbuster 2 pack epoxy mastic all the box sections have been sprayed with a waxoyl type of stuff, to be fair the subframe was mainly light surface rust, the way I look at it is how much you want to throw at it, if you want to do it yourself and how long in the real world the rest of the car will last!
What's your front subframe rust proofed with? 9 years 5 months ago #152602
Nice looking subframe - great job. Just needs that Aga enamel finish and you will have cracked it.
R
What's your front subframe rust proofed with? 9 years 5 months ago #152606
Now if you were talking of an enamel finish by said company of many years ago when stuff like lead flashing the castings and certain additives in the enamel that would be frowned on these days then Yes but if you are talking about "of late" I'll stick with my 2 pack it will chip less is repairable and look good for longer....... ;)
What's your front subframe rust proofed with? 9 years 5 months ago #152607
  • cjj's Avatar
Galvanised for me.
Although I have used the Rust.com epoxy mastic on the hubs etc.
Hammerite is rubbish. It looks nice when finished, but doesn't last long at all.
Last edit: Post by cjj.
Time to create page: 0.139 seconds
