Cracked wheel! 9 years 7 months ago #149540
  • Cobber's Avatar Topic Author
  • Away
As long as I've had the F there has been a very slow leak from the rear left tyre, I'd replaced the valve core, but that made no difference.
I was just going the put up with keeping an eye on the tyre pressure until I got around to replacing the tyres.
But over the last 2 weeks the leak has got worse.
I went to reinflate the tyre today and noticed the wheel is cracked!
So now I'm on the hunt for a standard alloy wheel to suit a 97 MGF 1.8 MPI
Forgive the picture quality, it was taken with the crappiest phone I've ever had, a shitbox Samsung S4
Last edit: Post by Cobber.
Cracked wheel! 9 years 7 months ago #149542
Wow. :omg:
Bit of superglue and job's a good'un. ;)
Cracked wheel! 9 years 7 months ago #149544
The following user(s) said Thank You: petetf160, Cobber
Cracked wheel! 9 years 7 months ago #149545
These guys are good, and they have loads of wheels for around £12 each with only a tenner postage.
Cracked wheel! 9 years 7 months ago #149549
£10 postage. Not to Australia though... :nonod:
Cracked wheel! 9 years 7 months ago #149550
Ah, then no lol.
Cracked wheel! 9 years 7 months ago #149553
The early F wheels always leaked air, the corrosion on the inside area of the wheel (only primed) causes the air to leak out between the paint and metal. i have one rear that is dropping pressure from 28psi to 15psi in about a week. Plenty of Mpi wheels available here in the UK for good prices, but expensive to ship to you, I should imagine. :-?
Cracked wheel! 9 years 7 months ago #149554
  • Away
Thanks for the thought, Sithmaull, but yeah the freight to Oz will be the killer!
Cracked wheel! 9 years 7 months ago #149565
  • PQD44's Avatar
You are looking at £59 delivery charge to Australia if sent by UPS via Transglobal Express. If you have any other small bits you need you should be able to put them in the package and not pay anymore provided they are less than a couple of Kgs
The following user(s) said Thank You: Cobber
Cracked wheel! 9 years 7 months ago #149591
  • Away
Thanks, but I should be able to get one here for less than the freight cost.
Cracked wheel! 9 years 7 months ago #149615
  • Away
I've managed to pick up a wheel locally.
Cracked wheel! 9 years 7 months ago #149618
:broon:
Time to create page: 0.988 seconds
