  • 2
EKA code does not work 9 years 8 months ago #147682
Had my local Rover garage to retrieve my EKA code which was lost but when I try to use it by turning the key in the lock the alarm is triggered. I have been told that it is the micro switches in the lock that is out of funktion. Can anyone tell me how to fix it?
EKA code does not work 9 years 8 months ago #147683
Are you following this?
Are your locks working normally otherwise? on the fob?
Does the interior light work properly?
EKA code does not work 9 years 8 months ago #147687
Perhaps I am not holding the key in lock position ( the first step) long enough. I will try this tomorrow. Otherwise everything is working as it should when I use the fob also the interior lights
EKA code does not work 9 years 8 months ago #147706
I was given the wrong code for my F by MG Rover codes, Russell gave me a different one when he used his T4 on my car, better check that it works??? :-?
EKA code does not work 9 years 8 months ago #147708
Where abouts are you, if you live anywhere near Heathrow Airport I will be able to retrieve your EKA code.
Jerry
EKA code does not work 9 years 8 months ago #147719
Mikstur lives in Denmark, so not too near Heathrow, Jerry. :nonod: ;) :P
EKA code does not work 9 years 8 months ago #147777
Thanks for the offer but as David has written I live in Copenhagen
EKA code does not work 9 years 8 months ago #147867
:-? I have now tried to unlock the car according to your information, but already when I turn the key to lock position, the alarm sounds after 4 seconds and I have to stop. I cannot even enter the code before the alarm goes. What is wrong?
EKA code does not work 9 years 8 months ago #147870
It can only be that the car thinks something is still unlocked. So either a door or boot lock is giving a faulty signal.
What I don't understand is how you can lock and unlock the car with the fob without a problem
EKA code does not work 9 years 8 months ago #147946
Yes it is strange that everything is working quite normal using the fob. There is no light indicating that a door or boot is inlocked. it is only for my own security that I want the door security code to work. I can live it not working but it is irritating
EKA code does not work 9 years 8 months ago #147952
I can only suggest that you try the alarm system test procedure.
The following user(s) said Thank You: Mikstur
EKA code does not work 9 years 8 months ago #147991
I seem to recall reading somewhere that some EKA codes on early MGF's were incorrect with I think the second and fourth digits needing to be increased by one to correct. i.e. 1234 should read 1335
A google search may provide the answer. I don't know if this will help.
I hope you can get it sorted soon. :drive:
Some days you are the pigeon and some days you are the statue.
  • 2
Time to create page: 0.118 seconds
