Odd, Mine worked perfectly without reprogramming. I did swap for the correct control unit as well as adding the passenger bag. It was plug and play.The physical fitting is straightforward and the wiring should be in place. However, you need a reprogramming to get the ECU to see the bag....I've even tried different ECUs with no success.....the. red SRS light stays on with the bag connected. Mine is disconnected and I'm hoping my kick starter diagnostics will allow me to sort this out.
Richard
