....Try a quarter turn in on the idle screw on the throttle body.
I had an issue with high idle; found to be a warped face on the crappy plastic inlet manifold (drawing air) I fitted an alloy manifold and 52mm throttle body from a Freelander, this cured the high idle but now I had hunting at idle. A re-set would cure the hunting for a bout a day but then it would come back.
I suspected the IAC so I fitted a new unit, this made no difference.
The cure for me was to get the engine up to normal operating temp and do a TPS re-set, re start the engine, unplug the IAC, remove the plastic inhibitor on the head of the idle screw, wind in the screw until the RPM just started to rise and then wind the screw out to get your 850 RPM, switch off and a final re-set.
Since then the idle (about 3k miles) the idle has been rock solid steady.
Brian.
