Door speaker woes! Recommendations? 10 years 2 days ago #142132
Hi All, I took the passenger door card off today to investigate my alarm troubles only to find that the door speaker was absolutely shot!! (I assume that the other one is not far behind). Should I replace 'like for like' from a breakers or does anyone have any recommendations for a new set up? I don't want to spend a fortune! :whistle:
Door speaker woes! Recommendations? 10 years 2 days ago #142133
  • bensewell's Avatar
I got see one nice pioneers from the Halfords sale rail they were under £20
The following user(s) said Thank You: Wizzywogga
Door speaker woes! Recommendations? 10 years 2 days ago #142149
Depends what you mean by "I don't want to spend a fortune!"?
The Alpine SXE-1750S are normally at a decent price. Here's an eBay link but they can be found on the web cheaper....
Alpine SXE-1750S 6-1/2"(16.5cm) Component 2-Way Car Speaker Kit 280W
Buy It Now
And then if you want the matching rears then I'd suggest the Alpine SXE-4625S -
Alpine SXE-4625S 4"x6" (10X15cm) Coaxial 2-Way Speakers Total 300W
Buy It Now
Good quality speakers and decent prices.
You could always just turn the stereo off and listen to the sound of the exhaust B)
Door speaker woes! Recommendations? 10 years 2 days ago #142154
Are those speakers a straight swap :broon:
Door speaker woes! Recommendations? 10 years 2 days ago #142155
You will find your current speakers have a plastic locator to hold them in place, the speaker is held into this with MG gunk! Heat the edge with a hair dryer and you can then fit any speakers of the same diameter. ;)
Door speaker woes! Recommendations? 10 years 1 day ago #142167
Well there's the answer apart from the front speakers are pop-rivited in, well on mine they are!
The ones I've quoted above are the correct sizes
The following user(s) said Thank You: John Pell
Door speaker woes! Recommendations? 10 years 1 day ago #142168
mine were also pop riveted, i carefully removed pop rivets and pop riveted new speakers into the holders, i guess you could also use self tapers if you don't have access to a pop rivet gun
Door speaker woes! Recommendations? 10 years 1 day ago #142187
I'm sure Clive has done a good how to for this.
Somebody did but I can't find it.
Last edit: Post by Metcalfe.
Door speaker woes! Recommendations? 10 years 1 day ago #142191
Clive's how to is here , I used that to sort mine out....pull the foam off the speaker, drill the rivets, melt the glue, swap the speakers. There is another guide showing the metal clip version instead of rivets
The following user(s) said Thank You: Metcalfe
Door speaker woes! Recommendations? 10 years 1 day ago #142193
Thanks everyone for your input. I'll keep on trawling the net until I find something suitable! ;)
Door speaker woes! Recommendations? 10 years 20 hours ago #142223
Pretty much any 6.5" ones fit...... i got some multi-cone ones from Makro dirt cheap.... sound decent to me!
Time to create page: 1.936 seconds
