Brian, do you know the readings for a mk 2 FUEL pump. I appear to have 2 black permanent earth. A green black ign on live and a white purple energised 3 second live on ign on.
Oh and no fuel flow
No noise at all from the pump on ign on.
My thoughts are fuel pump dead, but do those readings suggest otherwise?
Sent from my GT-I8190N using Tapatalk
Hi David,
From the schematic:
At the tank connection:
The 2 blacks are the individual earths; one for the sender unit and the other is the ground for the pump.
The green with the black tracer is the sender resistance feed out to the fuel gauge.
The white with the purple tracer is the positive feed for the fuel pump.
The under bonnet fuse F2 is the pump feed which goes through the inertia switch to the common of the fuel pump relay (brown/grey, permanent live with ignition off) The normally open contact of the relay (white/purple) goes to the pump.
The positive feed for the fuel pump relay coil is from interior fuse F14 (white, live with ignition on)
The ground signal for the fuel pump relay coil is from the engine ECU (black/purple) it becomes negative for a few seconds when the ignition is switched on, then negative when cranking or engine running.
I don’t know the resistance value for the fuel pump motor but you should be able to track down the fault with the above.
Good luck, Brian.
MGF up to 2001 Fuel pump schematic.
