I have checked for previous queries on this topic , hope I haven't missed a relevant one !
The car , 2004 , 1600 tf , the engine missed a couple of times close to home followed by
the engine management light . I bought a code reader which showed fuel shortage on no3
cylinder and general fuel shortage .
I have searched for the topic and relays seem to be the prime suspect.
So far I have;
Opened the tank inspection hatch , no power to the pump
Bought a replacement multi function relay for the boot mounted cluster
Checked / reset the inertia switch
Checked the under bonnet and dash fuses
Bought a new fuel filter (manual advises depressurising... no need, only a dribble of petrol)
Bought a secondhand YWB100970 engine management /fuel pump relay.........and there lies the
problem , where on earth does it live!
My manual shows a similar relay under the bonnet and also under the pressed steel guard
below the inspection hatch.....what I do have is a unit ,which I think is a security control unit
incorporating a large alloy heatsink mounted on the pressed steel guard and no obvious relay .
Am I correct in thinking the 2004 model has a different arrangement or ,more likely am I missing
the obvious (the polite version)
Any suggestions/ advice would be very welcome
