The Triple F build spec list 9 years 9 months ago #147285
Using 1mm perforated sheet as its stronger than mesh
It also looks better in that area.
The Triple F build spec list 9 years 9 months ago #147344
The following user(s) said Thank You: Cobber
The Triple F build spec list 9 years 9 months ago #147355
The more I see it the more I like your triple tailpipe set up
The following user(s) said Thank You: Diesel Destroyer
The Triple F build spec list 9 years 8 months ago #147445
Obviously still very much a work in progress
The Triple F build spec list 9 years 8 months ago #147453
You're going to have to point out all the oem parts on your build, Allan. :yesnod:
I know it's one nut and two small bolts, but where are they exactly? :shrug:
The Triple F build spec list 9 years 8 months ago #147456
The drive shafts are standard (but brand new)
And the rear view mirror is standard.. Apart from LED bulbs
The Triple F build spec list 9 years 8 months ago #147458
Disappointed now! :P
The Triple F build spec list 9 years 8 months ago #147694
Finally.. After ordering 2 months ago..
The Triple F build spec list 9 years 8 months ago #147698
They look a serious bit of kit, mind. :broon:
The Triple F build spec list 9 years 8 months ago #147701
Should of come from the factory with em on..
The Triple F build spec list 9 years 8 months ago #147750
One new arm fitted
Rear end stating to take shape
Glad I dropped the height of the bumper now to follow the lines of the car
Front bumper almost there.. Although fit/panel gaps to sort
The Triple F build spec list 9 years 8 months ago #147761
Starting to look as if it might run soon! :omg:
Time to create page: 0.228 seconds
