Hi David
AA patrolman couldnt tell me what problem is
He did check that engine fan was working, which it is
took car down to local garage and they replaced the oil filter, I have checked wiring to sensors which seem to be ok, but personally not sure what I should be looking for if i have disturbed wires to sensors.
took the car for a run after new oil filter fitted but oil temp still reaching 120 on a not too hard a run 80/90mph and in the rain so much cooler today than yesterday, oil light on dash has not flickered on again though
fella at the garage recommended i bleed the coolant again, although water temp is sitting below halfway ( so not sure if this could be part of the problem) and change the oil, i have been topping oil up with synthetic castrol 5/40 in and he recommended semi-synthetic 10/40, perhaps the problem is with the oil being too thin.
any more suggestions
Regards
Andy
