New from Holland 9 years 5 months ago #152669
Hello Iám Diana, and i have an MGF 1.8i charcoal black. We've last put on some new twist of pepper wheels and a new Red top. Now when my husband has time he is going to put on a new trevor taylor MK7 exhaust system.
We have also an irritating noise coming out of the right front end. we believe that has to do with the rubbers so we've also ordered some new powerflex rubbers.
that's all for now
Diana
The following user(s) said Thank You: KentJohn, mgtfbluestreak
New from Hollan 9 years 5 months ago #152672
:welcome2:
What kind of noise? Because the suspension looks very low. It looks as if the hydragas needs pumped up. :yesnod: That would cause rubbing noises.
Also a lot of creaking - squeaking noises are down to lack of grease in the top suspension arms. There are 4 grease nipples on the MGF, one on each top arm.
The following user(s) said Thank You: Diana Madonaa
New from Holland 9 years 5 months ago #152675
:welcome: :welcome:
[IMG]ht[/img]
New from Holland 9 years 5 months ago #152678
Hi and welcome.
New from Holland 9 years 5 months ago #152680
Babes, pepper wheels and a trevor taylor MK7 exhaust system! Yum, yum. How good can it get! :lol:
:welcome: Diana.
New from Holland 9 years 5 months ago #152690
  • Bertl's Avatar
  • Bertl
  • in the middle of the midlife crisis
Hi Diana, welcome aboard!
...nice wheels.
as ever,
Rob
New from Holland 9 years 5 months ago #152707
Hello all thank you for your reply's the hydrogas bolls are filled up now and the car is standing at a "normal" heigt now but the squaking is coming out of the right hand side. Can you tell me where the grease niples are so we can try that.
The noise is quite irritating but it comes from the right hand side
I hope you can help us out.
Kind regards
Diana
New from Holland 9 years 5 months ago #152708
:welcome: :welcome: :welcome:
New from Holland 9 years 5 months ago #152711
squeaking is coming out of the right hand side. Can you tell me where the grease niples are so we can try that.
Sorry, I don't know the answer to this, but maybe the how to guides have the answer.
SUSPENSION AND STEERING
Alignment and tracking figures - standard figures
Anti Roll Bar bushes front - Replacement guide.
Coil Spring replacement for Hydragas spheres - Replacement guide.
Compliance washers MGF - Replacement guide.
Hydragas - Releasing fluid pressure safely.
Lower Front Ball Joint Replacement - Excessive play solution and guide.
MGF bottom shocker bushes replacement - Replacement guide.
MGF Brace upgrade - Fitting a TF brace to an MGF.
Rear Hubs - Replacement guide.
Rear Track Control Arm - Refurbishment guide (TRE / Bush)
Rear Upper Suspension Arm (MGTF) - Replacement guide.
Steering left EPAS - Rectification guide.
Steering wheel removal and refit. - Steering wheel removal and refit guide.
Suspension - Balljoint -Upper front - Replacement guide.
Suspension Compliance Washers - Fitting guide.
Suspension - MGF Shocker lower bush - Replacement guide - Improving wear advice.
Track Rod Ends - Replacement guide.
Wandering - Steering checks.
If you don't find your answer, then maybe one of our other members with an MGF might know. So, keep checking back and good luck. :)
New from Holland 9 years 5 months ago #152716
Hello and welcome to the T bar.Here's a snap of when I did my grease nipples on my old F they are easy to see once you clean off the years of dirt covering them.The best way to find them is take off the wheels.There are four, one in each corner.
Last edit: Post by Bob.
Re:New from Holland 9 years 5 months ago #153250
The car looks stunning!
Time to create page: 0.137 seconds
